electric fan??
Old 03-31-2008, 10:26 PM
89mustangfive0
89mustangfive0's Avatar
Default electric fan??
i just bought and electric fan set-up on a 4 core radiator..i wanna put it on but perfoer not key on hot...any suggestions? and help would be greatt
89mustangfive0 is offline
Old 03-31-2008, 10:39 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: electric fan??
not key on hot??wtf?? what do you mean ?? you need to wire it up with a relay and to come on via a thermostatic fan switch
mjr46 is offline
Old 03-31-2008, 10:43 PM
89mustangfive0
thats what i figured...but what would be the best way to do it...the guy before me did it to the starter re-lay on the fenderwell so the fans were constantly on.
Old 03-31-2008, 10:46 PM
mjr46
mjr46's Avatar
sommit racing sells kits but the cheap way is go to your local parts store ..buy a 30 amp relay and fuse holder and wire the relay up to be triggered on via a thermostatic fan switch ,which can be purchased through summit for 25-30 dollars
mjr46 is offline
Old 03-31-2008, 10:47 PM
89mustangfive0
with that huge 4 core and it wired key on hot its not gonna reach running tempeture....i have the wiring on the fan what else do i need and where do i get it..
Old 03-31-2008, 10:53 PM
mjr46
mjr46's Avatar
here you need this!!
http://store.summitracing.com/partde...p;autoview=sku
mjr46 is offline
Old 03-31-2008, 10:57 PM
89mustangfive0
i found that tooo but i found the 40$ kit that has the thermostatic switch and relay..i have all the wiring already thanks !!
Old 03-31-2008, 11:07 PM
mjr46
mjr46's Avatar
cool!!!!..it's easy to wire up....and you can find a spot in the intake for the sending unit
mjr46 is offline
Old 03-31-2008, 11:14 PM
89mustangfive0
how does it get installed?
Old 03-31-2008, 11:19 PM
mjr46
mjr46's Avatar
sending unit goes in a coolant port.....you'll have to find a spot for that....and relay goes as such.. there will be two heavier wires on it = 1 to power wire of fan.... other to battery........ground neg wire of fan.....2 small wires on relay = 1 goes to sending unit and other goes to switched 12 volts....the relay kit comes with wiring instructions so no worry
mjr46 is offline
Quick Reply: electric fan??
