Are all 351w from 93-95 Roller motors
Old 04-05-2008, 12:27 PM
tmajikman
tmajikman's Avatar
Default Are all 351w from 93-95 Roller motors
Were all 351w motors from 93 through 95 all roller motors or were only the lightning motors roller types.
tmajikman is offline
Old 04-05-2008, 12:30 PM
w8less
w8less's Avatar
Default RE: Are all 351w from 93-95 Roller motors
i am pretty sure the roller 351's were from 94-98
w8less is offline
Old 04-05-2008, 12:34 PM
tmajikman
tmajikman's Avatar
so even the regular f150s were equipt with the 351w roller motor as well, not just the Lightning, just want to find out so that I can look into eventually locating one and knowing what years to look for will really help and save some money as well since lightning motors seem a bit pricey.
Old 04-05-2008, 01:14 PM
woodsy
woodsy's Avatar
Look for casting number F4TE, lightning engines were roller blocks but cam with flat tappet hyd cams
woodsy is offline
Old 04-05-2008, 01:18 PM
Joel5.0
Joel5.0's Avatar
Simply look for the casting number on the block (starter side), if it starts with F4TE, it's a roller ready block.
Joel5.0 is offline
Old 04-05-2008, 01:44 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
they started 351 rollers in 94
mjr46 is offline
Old 04-05-2008, 02:29 PM
tmajikman
tmajikman's Avatar
Cool, thanks everyone, time to mark this thread as a favorite so I will have those numbers.
Old 04-05-2008, 02:33 PM
tmajikman
tmajikman's Avatar
ORIGINAL: woodsy
Does that mean that they were not a true roller motor or what needs to be done to use a cam like the ones in our 5.0s.
Old 04-05-2008, 02:42 PM
mjr46
mjr46's Avatar
you'd need the lifter bar retainer and h-bars and maybe tap the two holes for retainer.. but they are compatible with roller cams
mjr46 is offline
Old 04-05-2008, 02:56 PM
tmajikman
tmajikman's Avatar
ORIGINAL: mjr46
Cool, thanks mjr.
Quick Reply: Are all 351w from 93-95 Roller motors
