tie rod question
tie rod question
just got my upr k member kit installed and im in the process of putting my 4cyl rack back on and i see that to get the tierods aligned there arent too many threads left on the end...... and it looks dangerous. what can i do to fix this?
RE: tie rod question
does the new k-member call for different length tie rod ends? id contact the manufacturer to see whats up. you should have at least 1 to 1.5" of thread engagement to be on the safe side. im pretty sure the v8 inner and outer tie rods are the same so its not that. does the new k-member increase track width possibly causing the problem? hope ya figure it out
im in the process of putting my car back together. it was a 4cyl... i have a full upr front k member kit and im not sure if i can use this rack or not because the tie rods are not long enough....
the wheel base on a 4 banger vs a 5.0 shouldn't be any different.. nor are the spindles...well actually they are but the parrallel that of a 85-86 10 inch rotor set up and I used a k-member kit on my 85 with such and the rack didn't give me any probs.....might want to measure a 5.0 rack and a 4 cyl one and compare the two
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
treesloth
09-28-2015 07:03 AM
yourmom6990
09-14-2015 10:52 PM
