little shake to the motor
RE: little shake to the motor
i just cant see it being the harmonic balancer bc its not missing any pieces and its not cracked. and its not like a horrible shake. and it only does it at idle it doesnt shake or miss or anything when you drive.
ORIGINAL: ant0045
Most likely cracked rubber motor mounts, or bolts loose.
A 5.0 stock, idles very smooth, no shakes, unless you have a vacumm leak, misfire, motor mounts, or just plain age. If performance is not affected, ignore it
my 2nd mustang had a little shake in the motor but it was caused by the K&N air filter that screwed in to place on the r/s valve cover creating a vacume leak I could unscrew it and cover it with my hand and the motor would stop shaking and idle 100% better
by the way i probablly should have said that i do not have the egr hooked up. and i have checked for vac leaks minus the vac lines underneath the intake manifold. also does anyone know how to get the hanging idle to stop?
