battery check light
Old 04-10-2008, 08:35 AM
PortStangly
PortStangly's Avatar
Default battery check light
Hey there,
I bought my 5.0 last fall, just starting to work on. On my way to work this morning I passed someone. Shortly after my battery light went on and my amps are down. Since my battery posts/cables were oxidized I thought it was time to change my battery. This being done there is no change in my amps or the presence of the battery light. My other thought is when changing the battery and also the clamps I noticed the copper in the +tive cable almost appears to look like plastic and the insulation within the cable appears to have deteriorated. Could it be as simple as replacing the battery cables? I was thing the alternator, but there are no other wonky issues with the lights/radio/signals and etc. Any ideas. I just want to be able to get home 30 miles away so I can take a better look.
thanks
PortStangly is offline
Old 04-10-2008, 08:43 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default RE: battery check light
could be improper grounding. check all connections and clean on the ends with a wire brush. worst case replace the battery cables if you like. i recently had some issues with my charging system but i clean on ends and grounds and made sure everything was attached securely. problem solved.
FivePointOhh is offline
Old 04-10-2008, 08:47 AM
PortStangly
Thanks for the info. I put new connectors on the same time as the new battery, this morning, no change. Maybe will try the new cables next.
raleigh05GTO
09-04-2015 07:09 AM
iamgobono
09-03-2015 12:37 PM
amandahchase
09-03-2015 10:09 AM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: battery check light
