Car died when in park
Old 04-17-2008, 06:20 PM
90notchLF
90notchLF's Avatar
Default Car died when in park
After driving my car for about 20 minutes I put it into park andall of a sudden itdiedI then restarted it with no problem and it stayed on. This has happen twice already and only when putting it into park after driving. My alternator is still good anyone know what this might be? thanks.
90notchLF is offline
Old 04-17-2008, 07:35 PM
1.9.9.4 pony
1.9.9.4 pony's Avatar
Default RE: Car died when in park
try adjusting your timming if not then maybe faulty spark is going threw your distributor cap or your rotor can be damaged
1.9.9.4 pony is offline
Old 04-17-2008, 08:05 PM
lxman1
lxman1's Avatar
Sounds like maybe your IAC is slow to react. Try cleaning it first.
lxman1 is offline
Old 04-17-2008, 11:15 PM
90notchLF
90notchLF's Avatar
I did a tune up about a month ago so I don't think it's the spark plug.
How would I go about adjusting my timeing and cleaning my IAC?
Old 04-17-2008, 11:51 PM
lxman1
lxman1's Avatar
If you haven't touched the timing, it usually won't just move unless the distributor is loose.
You take out the two 8mm bolts holding the IAC (idle air control valve) to the throttlebody. Unplug the 2 wire plug then remove it being careful not to tear the gasket. Then take some brake parts cleaner and spray out the plunger that is inside the two large holes really good. Sometimes carbon build-up makes them stick.
lxman1 is offline
djbigskrilla
09-20-2022 01:04 AM
3.7L V6 S550 Tech 2015 - 2017
92
08-24-2018 01:44 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
01blackgtconv
08-10-2015 01:25 PM
Quick Reply: Car died when in park
