86 gt over heats
Old 04-18-2008, 12:00 AM
Juanizzle
Juanizzle's Avatar
Default 86 gt over heats
yesterday the distributor took a crap on me while i was driving it. had to get the car towed home.
the thing is that it over heated when it shut off. now today when i got a new one, and after drving it for 2 miles, it marked HOT again. im not sure what it could be. DOESNT SMOKE, just reads hot.
got a new thermostat today and a new sending unit 3 days ago. im not sure what it could be.
any one got any ideas?
Juanizzle is offline
Old 04-18-2008, 12:03 AM
86 5.0L
86 5.0L's Avatar
Default RE: 86 gt over heats
water pump check the weep hole. original radiator? worn out fan clutch?
86 5.0L is offline
Old 04-18-2008, 12:18 AM
Juanizzle
Juanizzle's Avatar
i bought the car like this, it has a newer water pump, and a junk yard radiator.
EDIT: fan seems to work fine
Old 04-18-2008, 04:08 PM
86 5.0L
86 5.0L's Avatar
junkyard radiator? was it flushed/checked beforehand? is the top and bottom hose hot after driving around?
86 5.0L is offline
Old 04-18-2008, 06:52 PM
Juanizzle
Juanizzle's Avatar
i can squeeze the upper hose, its not super hot. i think the fan clutch relay might have to do something with it.
i got a 190F thermostat, might switch over to a 180 or 160. idk, ill also take the air out of the system.
Old 04-18-2008, 07:05 PM
86 5.0L
86 5.0L's Avatar
try a 180*
86 5.0L is offline
Old 04-18-2008, 10:11 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
bleed the cooling system properly!! turn heater on and wait until you get good heat = system bled.
mjr46 is offline
PaulH2
20
01-31-2016 09:48 AM
Explosive
10-02-2015 07:45 AM
folivier
10-02-2015 05:34 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Art161
09-09-2015 10:33 AM
Quick Reply: 86 gt over heats
