tranny problem
Old 04-26-2008, 11:17 PM
crocop
crocop's Avatar
Default tranny problem
i just got out my stang a few days ago and theres this problem it has that has continued form last year. basically i drive regularly in 1st up to lets say 3500 rpm ill push the clutch in and theres this bang shanking noise that comes from the tranny. only seems to do it when i push the clutch to shift into second. could the tranny be loose or something?
crocop is offline
Old 04-26-2008, 11:19 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: tranny problem
I'd check all the tranny bolts and bellhousing bolts
mjr46 is offline
Old 04-26-2008, 11:26 PM
crocop
crocop's Avatar
should i remove them one by one abd maybe put on locktite or is that not necessary
crocop is offline
Old 04-26-2008, 11:58 PM
mjr46
mjr46's Avatar
no loctite necessary...just check them and see if they are tight first..you are trying to find the problem so you are troubleshooting so therfore no repairs should be made until you locate exact prob...also check motor mount bolts and tranny mount bolts
mjr46 is offline
67LimeCoupe
09-30-2015 04:46 PM
prophotog
09-15-2015 08:38 AM
jaiidutch
09-14-2015 10:29 AM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: tranny problem
