stalling after mass air converson
Old 04-27-2008, 08:58 AM
50foshow
50foshow's Avatar
Default stalling after mass air converson
Hey fellas I converted my car to mass air and when i am comming to a stop it sometimes stalls or idels real low what could be the problems thanks
50foshow is offline
Old 04-27-2008, 09:10 AM
punisher91279
punisher91279's Avatar
Default RE: stalling after mass air converson
try adjusting your air idle screw, only turn it half a turn though.
punisher91279 is offline
Old 04-27-2008, 09:23 AM
5.0stanger
5.0stanger's Avatar
Did you add a VSS? I am sure that is your problem. Is it a 5 speed?
5.0stanger is offline
Old 04-27-2008, 10:44 AM
50foshow
50foshow's Avatar
no i dident do that what is the best way 2
50foshow is offline
Old 04-27-2008, 11:10 AM
5.0stanger
5.0stanger's Avatar
If your car doesn't have cruise, which I am guessing it doesn't, you will need to buy a VSS (vehicle speed sensor...got mine on ebay for $10) and a new speedo cable($25 at Advance Auto)for a car with cruise. Then you will have to go to a Ford dealer and buy a VSS pigtail ($5) and wire it in. The VSS is mounted where your speedo cable enters the tranny, so you will have to remove you speedo cable, and the gear from the cable, install the gear on your VSS, then install the VSS into the tranny, just like you were putting in you cable. Then you will have to put in your new cable. Wiring it is easy...when you get to that, follow these directions step number 6 http://www.stangnet.com/tech/maf/massairconversion.html. If you have any other questions about it. let me know, I have been thru it.
Old 04-27-2008, 11:52 AM
86302gt
86302gt's Avatar
also check the little rubber insert that goes in the maff conector i now it sounds stuped but mine did all most the same thing and i forgot to put in that lil ruber pice so just check it out
86302gt is offline
Old 04-27-2008, 03:09 PM
50foshow
50foshow's Avatar
well my car does have cruse control sooo haha idk thanks fellas
50foshow is offline
Old 04-27-2008, 06:41 PM
lxman1
lxman1's Avatar
What conversion kit did you use?
lxman1 is offline
Old 04-27-2008, 08:00 PM
gobabygo
gobabygo's Avatar
My car's having some of the same problems. It stalls and bogs when i give it alot of gas.
gobabygo is offline
Old 04-28-2008, 06:13 AM
50foshow
50foshow's Avatar
i just got the jumper harness its part of the ford racing conversion kit
50foshow is offline
Quick Reply: stalling after mass air converson
