How do I check the level of Gear Oil?
Old 04-28-2008, 03:07 PM
bbbngowc
bbbngowc's Avatar
Default How do I check the level of Gear Oil?
1991 Fox GT.
I was just wondering how to check the amount/level of Gear Oil in the gearbox? Automatic Trannys have a dipstick.
bbbngowc is offline
Old 04-28-2008, 03:11 PM
nseoi
nseoi's Avatar
Default RE: How do I check the level of Gear Oil?
under the car, on the passenger side of the tranny there are two 1/2" (ithink) plugs
the lower one is the drain, and the top one is the fill/max level plug
nseoi is offline
Old 04-28-2008, 03:19 PM
bbbngowc
bbbngowc's Avatar
ORIGINAL: nseoi
Ok, so the fill/max level has a plug. To check the level do I take out the plug? If gear oil comes out it's full? Need a lil more info [8D]
bbbngowc is offline
Old 04-28-2008, 03:32 PM
sultan68
sultan68's Avatar
i believe so yes, thats how the rear diff is
sultan68 is offline
Old 04-28-2008, 03:35 PM
Boss_Hotrod
Boss_Hotrod's Avatar
3/8" square drive plug. If fluid comes out its full unless it come flying out then its too full. The usual consensus is that if you can feel fluid when you stick your finger in its good. I usually go with fluid being level with the bottom of the plug.
Boss_Hotrod is offline
Old 04-28-2008, 04:22 PM
nseoi
nseoi's Avatar
oh btw you mentioned gear oil, do NOT put gear oil in a mustang t5, that is for the REAR END gears. most ppl around here use ATF or Mercon
i use mobil 1 synthetic ATF for my 5speed
nseoi is offline
Old 04-28-2008, 08:01 PM
bbbngowc
bbbngowc's Avatar
ORIGINAL: nseoi
Oh really?
I didn't know that. I have synthetic gear oil in it now. I'll drain it and refill it with GM Sychromesh.
bbbngowc is offline
djbigskrilla
09-20-2022 01:04 AM
JonnyBlazeGT
11-03-2015 01:10 AM
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
Itzjoe
08-26-2015 08:15 PM
Quick Reply: How do I check the level of Gear Oil?
