how do you adjust the fuel regulator
Old 04-28-2008, 08:58 PM
89stanger1989
89stanger1989's Avatar
Default how do you adjust the fuel regulator
i get 130 street miles to the tank and have no air leaks. i got vacuum gauge it reads 20 at idle. i want to play with the fuel regulator and see if it helps. how do you adjust it.
89stanger1989 is offline
Old 04-28-2008, 09:02 PM
brentloftis
brentloftis's Avatar
Default RE: how do you adjust the fuel regulator
Not to be a *** but do you have a adjustable FPR?
brentloftis is offline
Old 04-28-2008, 09:07 PM
calinotch
calinotch's Avatar
lol no can doozo ifyour stock buddy. get an aftermarket one and itll be pretty obvious how to mess with it.
calinotch is offline
Old 04-28-2008, 09:34 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
If your mileage is that low, there's an underlying issue that an afpr is not going to correct.
PRO50SC is offline
Old 04-28-2008, 09:55 PM
89stanger1989
lol yes i do. but if thats not the problem what can it be?
Old 04-28-2008, 10:02 PM
brentloftis
Do you know the model type of the FPR, most I have seen use a adjustment screw on top secured or locked by a jam nut on bottom, loosen the jam nut and adjust the screw clockwise or counter to raise or lower pressure.
Edit: tell us more about your car, from your screen name I assume its a 89GT? Any other mods or changes prior to the poor mileage. The gas has to be going somewhere, what does your exhaust smell like?
Old 04-28-2008, 10:16 PM
89stanger1989
its a lx with a 5.0 . i bought it borded out to 306 with crane cam rocker arms. not sure on the crank or cam but it doesnt idle to hard like a cam. headers, pullies,373, 8mm wire with the 2 prong spark plugs, and intake. the exhaust smells like gas but doesnt smoke much. i am only 18 and the gas is killing me
Old 04-28-2008, 10:27 PM
brentloftis
My friend, gas is killing us all..... I am almost considering driving my girlfriends ninja 250. For your problem it sounds like it could be a number of things but start at the cheapest and easiest. Clean Maf & IAC, listenfor vacuum leaks, check that the O2's are reading correctly/// I am sure there are more but I tired and going to bed.
Old 04-29-2008, 12:13 AM
cleanfitty
cleanfitty's Avatar
some have an adjustment screw where the vacuum plug goes. You do need a guage to set it right.
cleanfitty is offline
baddog671
07-26-2016 01:20 PM
Thunderball
15
11-22-2015 11:49 PM
svfetter
10-05-2015 11:39 AM
mrappe
09-26-2015 10:16 AM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: how do you adjust the fuel regulator
