need help with occasional rpm drop
RE: need help with occasional rpm drop
ORIGINAL: brentloftis
To replace the hose you only need to remove the upper plenum, and most of the time not all the way off, just enough to get access.
stuck after all this tweaking!! help
ok, i have replaced the IAC and have checked the base timing and its at about 10*.....when i put the spout connector back in it has trouble keeping a good idle...by good i mean constant ...it will revv to like 1500 then kill down to 1000 - 800 then the motor will look like its chuggin on the mounts then kick back up again....throttle response is good but somethings just not right...
so, so far i have done the following..
plugs, wires, cap & rotor, fuel filter, IAC valve, Coil, checked base timing =10*...any ideas now?
Matt's 95 Stang
10-05-2015 07:16 AM
