Strange clunk noise in rear???
Old 05-12-2008, 09:50 AM
hemi_04d
hemi_04d's Avatar
Default Strange clunk noise in rear???
So this is what I have, Edelbrock lower CA's, stock uppers, no quads and 2 in lowering springs. Sometimes when I go to take off I get a clunk noise. It almost sounds like its coming from the top of the shock tower but not real sure. Everything seems tight, and I had the rear suspension inspected and everything is new(shocks, springs, CA's) and I cannot figure it out.
I had a guy at a local shop(A mustang owner) check out the torque boxes and he says they are in great shape, and that compared to other fox's hes seen the undercarriage is probably one of the best as far as condition he has seen.
So where could it be coming from?
hemi_04d is offline
Old 05-12-2008, 01:03 PM
pk222
pk222's Avatar
Default RE: Strange clunk noise in rear???
possibly worn ring an pinion gears? not sure just have heard people with the same problem and that was what was making the noise a couple times.
pk222 is offline
Old 05-12-2008, 01:11 PM
hemi_04d
hemi_04d's Avatar
If that was the case wouldn't it be coming from the middle of the car? This seems to be coming from the rear pass. side of the car in the area of the shock tower. To me it almost sounds like something is loose, but I have checked, had 2 other people check and everything is tight.
hemi_04d is offline
Old 05-12-2008, 01:46 PM
brentloftis
brentloftis's Avatar
Is it a fast take off when you hear the clunk noise or anytime? Were the u-joints or wheel bearings inspected? When you take off the rear squats somewhat can you try to replicate the noise by applying weight to the rear passenger side, like pushing it down by hand? Also how is the exhaust routed and place it could be hitting or jarring enough to make the clunk?
brentloftis is offline
Old 05-12-2008, 02:05 PM
will
will's Avatar
check your upper shock studs make sure theyre not stripped common prob w stud mount shocks
will is offline
Old 05-12-2008, 02:59 PM
hemi_04d
hemi_04d's Avatar
The exhaust isn't in the way, when I put the trans back in, I had to losen it up to get the crossmember back in and made sure it wasn't hitting anything.
As far as U-Joints, I am pretty sure it isn't coming from there, they seemed good when I had the drive shaft out. Wheel bearings it might be though I will have to check those.
It seems to do it more if I am getting on it, but it also does it when I back up. As soon as I start moving is when you hear it, just a single "clunk" thats why I think it sounds like something moving that shouldn't be moving.
hemi_04d is offline
Old 05-12-2008, 03:28 PM
brentloftis
Yeah, sounds like wheel bearing to me but you can try this as well. Hold the brake down, shift to reverse (let off clutch a little if it is a manual) then shift to a forward gear (again with the clutch if manual) and back to reverse (clutch again) if you hear the EXACT noise then u-joints or pinion..... if not and only hear the noise when wheel is moving I would replace rear bearings.... not a hard job just time consuming.
Old 07-19-2012, 01:31 PM
mstrmstr
mstrmstr's Avatar
Here is a clue.. uncover shock tower to view stub end of shock. Jack car up if you dont have access to a rack. You should NOT see the shock moving up and down at the attachment. When some guys change shocks they overlook or forget the neoprene lower donut which allows the shock to actually bang the tower every bump you hit that unloads the suspension. Another note is a broken shock tower.
When I put mine on the rack and moved the car up and down it was easy to see and hear the problem.. A 10 minute fix.
mstrmstr is offline
bjdutch2005
03-24-2017 03:38 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
67LimeCoupe
09-30-2015 04:46 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Strange clunk noise in rear???
