top end install..
RE: top end install..
ORIGINAL: 88_5.0
any suggestions on combo's then?
ORIGINAL: mjr46
for the price of a trick flow kit you could piece together a better set up that'll yield more power
The only thing I can recommend is after the swap is said and done, take the car and get it professionally tuned! The Trickflow kit isn't given the credit it deserves because of people just slapping it on and taking it to the dyno. There's a guy that lives local to me that runs around in a 94GT similar to mine. He has the Trickflow HCI out of the box, longtubes, exhaust, 75mm tb, 76mm MAF, and pullies. He dyno'd 309rwhp and 327rwtq. It don't get much better then that with a HCI swap on a 302.
good info guys, appreciate it. Other than a harmonic dampner puller and a fuel line removal tool, are there any other special tools i will need? i've got a pretty extensive set of tools but not really any specialized stuff.
ORIGINAL: 88_5.0
ORIGINAL: highspeed
Be careful not go to excesive with the cam lift... you don't want to damage your new Heads or Valves with piston and valve clearance issues.
To the original poster, many guys have gotten 300 RWHP from a Trickflow Kit. Just ask them to hold the valve covers, and you have nice deal per dollars spent.
ORIGINAL: CantStopTheFox...
Torque Wrench...and a few cases of Beer
ORIGINAL: 88_5.0
ORIGINAL: 5spd GT
Peak lift has nothing to do with piston to valve clearance.
ORIGINAL: highspeed
ORIGINAL: 88_5.0
will the stock valve covers work with the TF head? clearance? or will there need to be some modifications made on the baffles?
ORIGINAL: 5spd GT
Don't the Trick flow kits come with valve covers?
ORIGINAL: highspeed
ORIGINAL: smythge
ORIGINAL: 88_5.0
ORIGINAL: 5spd GT
ORIGINAL: highspeed
