5.0 Rebuild question
Old 05-14-2008, 04:58 PM
icelandismine
icelandismine's Avatar
Default 5.0 Rebuild question
Hi all,
I just bought my '91 4 banger, and I'm getting parts to do the 302 swap on it. I just have a couple of questions. I'm either going to stroke or boost the motor eventually. Stroking I'm pretty sure I got a good grasp on, but as far as boosting it, I'm not so sure. If I was planning on putting a supercharger/turbo on it, are there any specific parts I should install when rebuilding the motor, or can the stock 5.0 components hold up? Also, where are some good places to look for said super/turbochargers? Any opinions on used ones?
Thanks!
icelandismine is offline
Old 05-14-2008, 05:32 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: 5.0 Rebuild question
forged pistons and rods, possibley a cast steel crank...but no need to do a forged craank unless of course you use an aftermarket block and plan to run tons of boost
mjr46 is offline
Old 05-14-2008, 05:40 PM
icelandismine
How much am I looking at for forged pistons and rods?
Old 05-14-2008, 05:47 PM
mjr46
mjr46's Avatar
ORIGINAL: icelandismine
factory roller h.o blocks up to 92 came with forged pistons but if you plan to get aftermarket stuff expect to spend 500-700 on a decent set of forged pistons and rods
mjr46 is offline
Old 05-14-2008, 09:38 PM
icelandismine
Ouch. Ouch. OUCH. I guess if I'm doing a rebuild anyways it might not be too bad, but still...
Might just stroke it now. Probably a decent bit cheaper.
Old 05-14-2008, 10:12 PM
mjr46
mjr46's Avatar
uhhhh nope!!!!!!!!..you wanna stroke a 302 , you need stroker parts!! ie..cam, intake, heads , exhaust and so forth suited for a stroker for example a 347..when it's all said and done you'll have thousands invested in it to run well
mjr46 is offline
Old 05-15-2008, 05:40 PM
icelandismine
Hm. Well, then maybe boosting it will be better...less initial investment. Forged pistons and rods, decent heads and intake, and leave at that until I get the actal turbo or supercharger.
Old 05-15-2008, 05:50 PM
wrenchturner75
wrenchturner75's Avatar
horsepower=$ either way your gonna spend it, its real easy to sink 5 grand into a stroker depending on how you want it built and to boost it or turbo it well skys the limit.
wrenchturner75 is offline
Old 05-15-2008, 07:06 PM
simpsonfan13
ELEKTRO-FIDE Moderator
simpsonfan13's Avatar
Location: In Geo-synchronous orbit over redass' bathroom,
ORIGINAL: wrenchturner75
agreed
check the price for the entry level supercharger from vortech
the blower it self is over $2300
then add in
an upgraded fuel system
upgraded suspension (you need to be able to plant that power to use it)
beefed up tranny (i think the T-5 can only hold ~300hp, correct me if im wrong)
forged internals (as previously discussed)
for the love of god a good tune (many people dont know how important this really is)
there is a saying in the car world
"good, fast, cheap. you can only have two out of three"
simpsonfan13 is offline
Old 05-15-2008, 07:10 PM
icelandismine
I'm not so concerned with cost, but I'd like to get that 4 cylinder out as soon as possible, and if I supercharge the V8, most of the cost comes later on...
Quick Reply: 5.0 Rebuild question
