Ignition control module(TFI) question......
I posted a couple weeks back how my Stang would run fine for 10 minutes then die while driving. After it sat for 10 minutes it would start up and I could make it home. I replaced the TFI module on the distributor and the car ran great for 2 weeks. Last night I went to pick up some take out and the Stang would not start! I had it towed home and it started right up after the tow truck left!!! I did buy the ignition module at AutoZone, is it possible that the new one is shot? Does MSD sell just the module? I have MSD distributor, coil and wires. I know I have fuel pressure because I have a fuel pressure gauge in the Stang. Any help would be much appreciated! -Dave
RE: Ignition control module(TFI) question......
MSD sells the TFI Module...This is the one I got:
http://www.latemodelrestoration.com/...1&comp=LRS
Dave, you need to repeat the tests described here to make sure it's a no spark condition you're dealing with........ with the engine under the "no start" condition. LUK
