new spec clutch= problems
Just picked up my 88 gt from the mechanic, he installed a spec stage 1. When the clutch pedal is fully out at idle it, there is some clutch noise. The mechanic said it sounds like the throwout bearing is vibrating slightly butonce the clutch pedal is pushed down just a centimeter the rattle sounds stops?
The car also vibrates and shakes real bad as you are letting the outclutch getting the car moving in first or reverse. Once i am moving it drives great. WHAT THE F*%&!!!
I'm sure the mechanic did it right because he has done all the work on my car, and has had many mustangs himself.
Has anyone else had problems like this? Does it just need to be broken in? Did I maybe get a factory defect?
RE: new spec clutch= problems
the engagement point is perfect (about half way) and the car shifts fine once moving. when i try start moving the car shakes so bad i feel like something is gonna break. I think i am goin to call SPEC and bitch tommorrow.
ORIGINAL: ptown87
just use the gas a little bit more. I noticed if I brought my RPM's up a little more than i normally did. I had no chatter at all.
It's a new clutch... deal with it!
