what does this thing do? blocking my vacuum
Old 05-18-2008, 08:34 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: what does this thing do? blocking my vacuum
brake booster should be hooked to vaccum tree and from there ...there will be numerous hoses connected to manifold vaccum sources which supply vaccum to booster..as long as no hose is plugged it should work.. there is also a 1 way check valve on the booster..it pushes into the rubber grommet on the booster..check that and you should be able to only blow in one direction through it..or suck in one direction
mjr46 is offline
EASTIDEE123
09-15-2015 11:08 AM
rksnow1
09-14-2015 08:46 PM
TfcCDR
09-14-2015 12:08 PM
rdog69t
SVT Forums
09-13-2015 06:16 PM
09-08-2015 05:21 PM
Quick Reply: what does this thing do? blocking my vacuum
