Weiand Supercharger
Old 05-20-2008, 09:19 AM
smythge
smythge's Avatar
Default Weiand Supercharger
I am looking at purchasing the Weiand roots 174 supercharger http://www.holley.com/77-174FSBP-1.asp. I have a 1991carburated 302currently running this setuphttp://www.marchperf.com/instruction...structions.pdfwith only the water pump and alternator. The water pump is forward rotation from an 85 crown vic. Iplan on switching to this setup to drop the alternator down. http://www.marchperf.com/instruction...structions.pdf which should solve any clearance issues with the alternator and blower. The problem I am having is getting a straight answer on which pulleys I need to run.The tech dept at Weiand told me that the kit was designed to be used with 70-78 stamped steel V-belt pullies, I have no problem with that, but I am having a hard time finding a set under $200 which seem a littleexpensive forstock pulleys. Anyone have any ideas or experience with this setup and what mightwork for me?Any help is appreciated.
smythge is offline
Old 05-20-2008, 09:28 AM
HACKGT350
HACKGT350's Avatar
Default RE: Weiand Supercharger
how much did that alt set up run you? thats what i need
HACKGT350 is offline
Old 05-20-2008, 09:49 AM
smythge
smythge's Avatar
ORIGINAL: HACKGT350
It was about $175.00 If you give me a couple weeks I won't need this one and will sell it cheap.
smythge is offline
Old 05-20-2008, 10:09 AM
HACKGT350
HACKGT350's Avatar
sounds good to me...as for your pulley problem you might just have to spend a bunch of money on them, i dont even know anyone else on here running one of those blowers but there could be someone lerking around
GimpyHSHS
19
12-19-2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
col2560
09-25-2015 08:59 PM
Quick Reply: Weiand Supercharger
