complete 97' explorer rearend ?
Would it be possible to fit a 97' exploder 8.8 rearend with 3.73s with disc brakes under my 88' GT. If it is, how bad is it to install?
How bad would it be to put my stock 4 lug axels in the explorer rearend? Is it just pull and push?
RE: complete 97' explorer rearend ?
I don't know if the explorer has the same track width as a mustang. Also your stock 8.8 has clips so you going to have to open the diff cover up and you will have to get 4 lug rotors for the axle. call Drive Train Specailites in Warren Michigan they will be able to help you out
The explorer uses an offset pinion, so it will not fit. I actually narrowed one to fit in a 65 dart here is a link to the project. http://www.forabodiesonly.com/mopar/...ead.php?t=9224
jwog666
12-27-2021 08:09 PM
