rearend swap ?
Old 05-22-2008, 11:20 PM
Ze2222
Ze2222's Avatar
Default rearend swap ?
Hi guys thinking of swappin my rear end in my foxbody for one of a sn95 cause i wanna do the 5 lug conversion my question is i hear the axles are longer? so will that set me out too far, from me using a 15x10 tire with 275/50/r15 rubber? will i rub
or could i just use the sn95 axles with my original 8.8 from my car and shave down the axle ends.. or did i hear wrong and the axles are the same size?
Ze2222 is offline
Old 05-22-2008, 11:36 PM
RoadsterRider
RoadsterRider's Avatar
Default RE: rearend swap ?
I'm pretty sure the axles have to come out of a ranger or aerostar and the spindles can come off of the SN95.
RoadsterRider is offline
Old 05-23-2008, 01:40 AM
primetime5.0
primetime5.0's Avatar
dont use the sn 95 rear, like stated above get axles from a ranger from the junkyard and keep the stock width, chances are your not going to fit a 15x10 back there anyways
primetime5.0 is offline
Old 05-23-2008, 01:50 AM
w8less
w8less's Avatar
i thought for the ranger axles you had to get to left ones or something like that. please correct me if i am wrong. just thought i read that on here
w8less is offline
Old 05-23-2008, 02:28 AM
primetime5.0
IIRC it is driver side only.. if anyone wants to buy a set I have some!
Old 05-23-2008, 08:18 AM
stang8689
stang8689's Avatar
Thw sn-95's have discs and are 3/4" wider per side
stang8689 is offline
Old 05-23-2008, 05:04 PM
Ze2222
Ze2222's Avatar
thx for the suggestions.. so what year ranger? and where do i get the 5 lug spindles from? same ranger.. also i can only use d/s axle. what about passenger? what would i use therE?
Ze2222 is offline
Old 05-23-2008, 09:05 PM
Ze2222
Ze2222's Avatar
?anyone?
Ze2222 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: rearend swap ?
