carb. distributor
Old 05-23-2008, 09:37 PM
need2know
need2know's Avatar
Default carb. distributor
i have a distributor from a 85 to carburate my 89 and i was told that there was a link or website that would show how to wire this up cause im not sure how it only has 2 wires coming from it and i was told it wires up something like a chevy . I do no.
thanks
need2know is offline
Old 05-23-2008, 09:39 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: carb. distributor
pics!!!are you using the duraspark dizzy?? it should have 3 wires and you'll need the box and a duraspark coil
mjr46 is offline
Old 05-23-2008, 09:45 PM
need2know
need2know's Avatar
yeah but im not sure how to wire it to the existing harness cause i was told it goes from the distrib. to a resister like
Old 05-23-2008, 09:47 PM
mjr46
mjr46's Avatar
ORIGINAL: need2know
huh??? wire what to existing harness?? not to the efi harness...all you need for duraspark is a switched 12v source and ground
mjr46 is offline
Old 05-23-2008, 09:51 PM
need2know
need2know's Avatar
ok... so i just need a hot wire from a 12 v. and ground it off and itll work ?
Old 05-23-2008, 09:57 PM
mjr46
mjr46's Avatar
ORIGINAL: need2know
these are the parts you need duraspark box, duraspark coil, and duraspark dizzy
http://i242.photobucket.com/albums/f...raspark001.jpg
mjr46 is offline
Old 05-23-2008, 10:00 PM
mjr46
mjr46's Avatar
see on my box there are two pigtail connectors.. the one with two = red to switched 12v...white to ground
other connector with 4 wires = green goes to neg side of coil....the other three wires get matched = purple, orange and black to corresponding colors on dizzy connector and POS side of coil gets wired to switche 12v or tapped off of red switched 12 on box connector
mjr46 is offline
Old 05-23-2008, 10:03 PM
need2know
need2know's Avatar
ok i see hey thanks alot i really appreciate all the help
Old 05-23-2008, 10:06 PM
mjr46
mjr46's Avatar
anytime
mjr46 is offline
Old 05-24-2008, 09:07 AM
imnotmy77stang
imnotmy77stang's Avatar
why use a stock duraspark unit when y ou can pick up a used msd 6al cheap or even better find a crane hi-6
imnotmy77stang is offline
Quick Reply: carb. distributor
