Strut & Caster Camber plates won't fit???
Old 05-25-2008, 12:32 AM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: Strut & Caster Camber plates won't fit???
I use FRPP CC plates. with the stock struts you have to instal spacers to take up the extra slack between the dust boot and the plate... otherwise they would be flopping around.
I can get pics tomorrow!
AdderMk2 is offline
Old 05-25-2008, 07:15 AM
capri debris
capri debris's Avatar
ORIGINAL: stang8689
I have KYB struts with Hotckis c/c plates. Hotchkis includes everything you need including bushings and boots. Its very high quality and is much thicker than BBK or Mac. You will be very happy with it, check into hotchkis.
http://www.mustangsunlimited.com/ite...p;CatKey=74-01
Stang8689... that's the ticket!!! It has everything I'm in need of... quality aluminum plates, bump stops, urethane bushings and dust boots. I just want to make sure you and Ihave the same type of KYB struts. If we do and the Hotchkis kit works on your car, I'll be ordering some on Tuesday. Here's a pic of the strut I have... they are silver and have a sticker on the side that says GR-2
capri debris is offline
Old 05-25-2008, 10:06 AM
stang8689
stang8689's Avatar
You won't be dissapointed, they are made of great quality. Wait till you see how much thicker they are than your Macs. It was very easy to install as well and are the best looking in my opinion
stang8689 is offline
jwog666
12-27-2021 08:09 PM
Lethaldosage423
10-19-2015 12:12 AM
col2560
09-25-2015 08:59 PM
09-25-2015 09:06 AM
RWHEELS
09-05-2015 03:42 PM
Quick Reply: Strut & Caster Camber plates won't fit???
