Too much crankcase pressure
Other than the PCV, what else could be causing me to be building up to much pressure in the crankcase. Im getting oil blowing out of my breather cap on my valve cover, and my oil stick keeps blowing out of the dipstick tube.
RE: Too much crankcase pressure
motor is worn out most likely... if the screen/mesh through which the pcv system draws vapors under the grommet is plugged up that to could cause it.....but perform a compression test while your at it to verify internal integrity
ccdguy
09-19-2015 05:20 PM
09-08-2015 11:50 AM
