carb question help plz
Old 06-04-2008, 09:57 PM
silentvoice19
silentvoice19's Avatar
Default carb question help plz
Ok guys i got a 351 and im goin carb I was wondering if anyone have any really good wireing diagrams or a decent place that could help me. Ive been to one place but didnt help to much it didnt have pics. I am a pic orientented guy.Also fuel pump wise how do i go about doin that? i know i can use a holly blue but.......how do i hook it up? what do i do about the fuel pump hanger. I can do this i know i can i just need acouple websites and what not.Btw i know what all is required for the swap like oil pan 28oz flywheel etc.
silentvoice19 is offline
Old 06-04-2008, 10:03 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: carb question help plz
get a relay and wire it to switched 12v to run pump and mount pump in a safe place at rear = works better as a pusher vs puller...and holley blue needs to be used with a regulator
mjr46 is offline
Old 06-04-2008, 10:11 PM
silentvoice19
ok mjr ur awesome but let me make sure im gettin ya here. Use my 255lph i have in there now and snag a relay and just wire to a switch 12v?Am i on the button?
Old 06-05-2008, 05:38 PM
tinman
tinman's Avatar
No, wrong.
That 255LPH pump is an injection pump.
A carb pump will not have as much pressure as carbs don't need more 7# ever.
Use the Holly blue with it's regulator AFTER you get the 255 out of the tank.
I agree with the relay idea too....
tinman is offline
Old 06-05-2008, 06:07 PM
FLcracker9
FLcracker9's Avatar
Some one may correct me if I'm wrong, but I believe Joel is using the stock in tank EFI pump, with a return type regulator (5 - 7 psi), and it works fine?. That's what I was planning on doing to my 89?. If that won't work,I'll do like I did on my Son's 86 F150, install the Holley blue as close to the tank and as low aspossible, disconnect the EFI pump and use that wire for the blue pump (I believe this keeps the relay and inertia switch intact), and install a regulator near the carb. I left the old pump in the tank, and the holley pump siphons the fuel through the disconnected pump with no problem, eliminatingthe need for a custom fuel pickup or a sump in the tank. This hasbeen working for 2 years now on the F150, and it's a daily driver.
FLcracker9 is offline
Old 06-05-2008, 07:43 PM
silentvoice19
nice guys thanks for the info
Old 06-07-2008, 11:28 PM
silentvoice19
hey what do you guys thinki should do man stay EFI on my 351 or go carb...........Im confused here lol.I dont mind about the reliability and i hear carbs are fairly reliable but efo is tried and true.This car is gonne be kinda of a DD but not lol maby 3-4 days out of the 7.
Old 06-08-2008, 12:03 AM
67mustang302
67mustang302's Avatar
Considering carbs have been around 5x longer than EFI, I'd have to say the carb is the tried and true. They each have their advantages.
67mustang302 is offline
Old 06-08-2008, 12:42 AM
silentvoice19
yea im lookin into it and some of the new carbs have made tuning alot easier. I just need to find a good cost effective carb.Nothing too exp but notin doller general cheap lol.Elec choke prefered. Im gonna put a set of heads on it soon 205cc prolly.And maby a cam so im assuming a 725cfm should be good to go.What do you guys think?
Old 06-08-2008, 01:07 AM
67mustang302
If you plan on turning a lot of rpm, yeah.
Quick Reply: carb question help plz
