Quick GT40 heads questions
Old 06-07-2008, 09:37 PM
Chr1s46536
Chr1s46536's Avatar
Default Quick GT40 heads questions
Ok the search isnt working for my so i was just wondering some quick questions about gt40 heads and upper/lower intake
1. Can i reuse the pushrods when i swap the heads in?
2.Do i need to take any of the fuel rails or sensors/wires with the intake?
3.Do i reuse my same head bolts with the swap?
Thanks
Chr1s46536 is offline
Old 06-07-2008, 09:51 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Quick GT40 heads questions
as for head bolts if they were stock torque to yield ones I wouldn't reuse them but it depends on what year motor your working on...lack of info makes it difficult to give an accurate answer...as for fuel rails ??? what are you doing ??? and as for push rods it all depends on what rockers you are using ..if using roller rockers it 's best to measure and check for proper push rod length but since they are stock heads.. stock push rods should be fine
mjr46 is offline
Old 06-07-2008, 10:35 PM
Chr1s46536
Chr1s46536's Avatar
Just swapping a GT40 intake and GT40 heads onto a stock 90 GT
Old 06-07-2008, 10:47 PM
stang8689
stang8689's Avatar
I would get ARP bolts
stang8689 is offline
Old 06-07-2008, 10:59 PM
mjr46
mjr46's Avatar
then most of the gt-40 stock stuff should be a direct transfer
mjr46 is offline
Old 06-08-2008, 12:20 AM
nacanitihs
nacanitihs's Avatar
what about having them milled? would that have any effect on pushrod length? if used w/ 1.6 rockers and a .512 lift cam?
nacanitihs is offline
tmdm
05-02-2021 02:49 PM
ctgreddy
09-20-2015 08:35 PM
Mustangmalo
09-06-2015 05:22 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Quick GT40 heads questions
