Car running like dookie <<<Bad Injector?!
Old 06-13-2008, 10:45 PM
  #51
tw3ak
tw3ak's Avatar
Default RE: Car running like dookie <<<Bad Injector?!
u have hard srarting.. thats one thing i dont have. I cleaned the maf this afternoon and still nothing D:
Did you try doing whatBoss_Hotrod said? The cylinder balance test?
tw3ak is offline
Old 06-13-2008, 10:47 PM
  #52
kennebellgt
kennebellgt's Avatar
yes, all cylinders are fine 90 came up and im fine. man this sucks i think i have a bad maf sensor.
kennebellgt is offline
Old 06-13-2008, 10:51 PM
  #53
tw3ak
tw3ak's Avatar
ahh cool u passed. u have to finda mafto borrow so you can test!
tw3ak is offline
Old 06-13-2008, 11:38 PM
  #54
kennebellgt
yeah im going to well good luck when you find your problem pm me, also your stang is badass ashame its ****ing up but thats just 5.0 for you lol i love mine but thats how they are
Old 06-13-2008, 11:44 PM
  #55
tw3ak
tw3ak's Avatar
Thanks man. Good luck also. Likewise, if you figure your prob out let me know. oh by the way.....you ride is wayyyy sexier!
tw3ak is offline
Old 06-15-2008, 10:46 PM
  #56
Boss_Hotrod
Boss_Hotrod's Avatar
Kennebellgt you might be having the same problem I had. The sensor in my distributor went bad. Would buck and carry on when hot and would be hard to start when it got hot. Now I just think my starter is getting heat soaked due to the longs since it starts quicker but is still a little slow. One more thing you guys should check should be your timing chain. Eay way to tell this (without pulling the cover) is to use a timing light and see how bad a mark at 10 (stock base timing) moves around on the balancer. If its erratic your chain could be shoot and cause all kinds of firing issues.
Boss_Hotrod is offline
Old 06-15-2008, 11:07 PM
  #57
tdecario
tdecario's Avatar
hey guys. another thing i would check for is the IAC. i had a similar problem with my old 5.0. car would run fine for a lil bit, and then back fire, and miss like crazy. this problem also drove me nuts. the way i figured it out was i pulled my old one out and sprayed the hell out of it with carb cleaner to clean it out. it ran somewhat better, still bogged, but didnt missfire. when they go bad, its time to replace them, but i figure i should throw this idea out to you guys.
tdecario is offline
Old 06-15-2008, 11:34 PM
  #58
tw3ak
tw3ak's Avatar
Thanks for the info guys. My IAC is fairly new, I took it off and it was barely brown... still looked kinda new. I will check the timing tomorrow. Thanks Boss_Hotrod.
Well i changed out my o2 harness and 1 o2 and it seems to be driving alot better. My old harness was chopped and screwed. It might havetaken care ofthe major issue(s)I was having. I took her out for a little cruise tonight and she was running like a champ compared to before. Iwill knowtomorrow if it was the problem for sure after I drive some more. Thanks for all the help guys.
tw3ak is offline
Old 06-16-2008, 08:22 AM
  #59
TTGreenSN95
TTGreenSN95's Avatar
you cant run a pcv valve and open valve coversit will cuase a vacaum leak.
if you think its an injector drive it for awhile then pull the plugs and look for a really clean one or one thats burning the elctrode I had a pluggeg injector and this is how I found it.
there is an ect probe on the lower intake it is a fuel multyplier for incoming cold air they get right nasty on the foxes pull it out and clean it or replace it should be on the lower intake right front......
dont know if this will help just my 2 cents.
TTGreenSN95 is offline
Old 06-16-2008, 11:59 AM
  #60
tw3ak
tw3ak's Avatar
ORIGINAL: TTGreenSN95
Well I had to put a breather in one of the valve covers because the pcv valve kept blowing out and spitting oil eveywhere. (i think its the supercharger thats causing that) Should I just put a pcv in the valvecover and run a vaccum line to the tb?
tw3ak is offline
djbigskrilla
09-20-2022 01:04 AM
mstahoo
SVT Forums
08-19-2021 09:15 PM
jjwinel78
08-17-2015 03:34 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Car running like dookie <<<Bad Injector?!
