Grinding ?
Old 06-19-2008, 05:35 PM
  #21
djh1121
djh1121's Avatar
Default RE: Grinding ?
Wow, not my area of knowledge for sure but something isn't right. You did buy a new clutch and used the same PP, right? It lust looks like the disc is being pressed against the flywheel.
This maybe a dumb question but could the clutch disc be on backwards?
djh1121 is offline
Old 06-19-2008, 05:40 PM
  #22
bighungrymatt
bighungrymatt's Avatar
that was one of my thoughts. but there is only 1 way to put the disc on. after I took it off it was on correctly.
I did use the old pressure plate and tob.
I dropped the flywheel off at the machine shop in west jacksontoday to get resurfaced and am picking it up tomorrow while I am out that way
bighungrymatt is offline
Old 06-20-2008, 08:16 AM
  #23
AdderMk2
Banned
AdderMk2's Avatar
My Spec never did that...
Just one more reason NOT to buy a centerforce!
AdderMk2 is offline
Old 06-20-2008, 10:36 AM
  #24
bighungrymatt
yeah I dont know what the deal was. my last centerforce worked just fine
Old 06-20-2008, 10:44 AM
  #25
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: AdderMk2
[sm=loser.gif]
There's nothing wrong w/ Centerforce. I will be surprised if it's the flywheel. Reason being, once the disk engages, there is no more movement in that area. If you have noise while you're driving, I would look to the t/o or the pilot bearing.
How do you know it's not the news'd tranny?
PRO50SC is offline
Old 06-20-2008, 11:27 AM
  #26
bighungrymatt
I havent driven it, therear is on jackstands. I cranked itbecause it has been sitting a month.
The noise was doing it in neutral without the clutch engaged.
I got under the car and it sounded like it was coming from bellhousing area. I had the clutch cable cover off and it looked like the clutch fork/cable was vibrating
I ordered a new tob, pilot bearing, &resurfaced flywheel, so we will see. I wont be able to work on it until tuesday evening
I thought the transmission didnt spin in neutral? well that is what I was told
KingRando
10-02-2015 08:06 AM
JDWalton
09-24-2015 08:47 PM
degner122
09-16-2015 07:09 AM
raleigh05GTO
09-04-2015 07:09 AM
duffman668
08-26-2015 04:46 PM
Quick Reply: Grinding ?
