problems.
Old 06-23-2008, 03:56 PM
saocore88
saocore88's Avatar
Default problems.
i have a 92 5.0 efi. ive been having problems with it. i recently replaced the trans. now when i turn on the car and the clutch is engaged it has a horrible wining sound. when i let go of the clutch it stops. also the idle will get stuck at 1300. ill drive the car when its cold and it will be fine, when it reaches operating temp it trys to shut off or the idle will jump up and down. i really cant figure out the problem. any suggestions?
92 hatchback
bbk longtube headers
65 mm throttle body
e303 cam
king cobra clutch
hurst short throw
3.55 gears
bbk cold air intake
ford racing aluminum driveshaft
saocore88 is offline
Old 06-23-2008, 06:04 PM
vogs77
vogs77's Avatar
Default RE: problems.
Did you replace the pilot shaft bearing in the back of the engine???
vogs77 is offline
Old 06-23-2008, 07:40 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
sounds like the throw out bearing is bad for the clutch
mjr46 is offline
CS2007
06-25-2019 09:45 PM
ChampInSD
10-02-2015 04:55 AM
zanemoseley
09-06-2015 12:58 PM
movielover40
08-27-2015 03:26 PM
DrunknRuckus
08-23-2015 10:05 AM
Quick Reply: problems.
