passing emissions
Old 06-30-2008, 09:31 PM
ctlazersplaya07
ctlazersplaya07's Avatar
Default passing emissions
hey, i just bought an offroad x-pipe with no cats on it....i want to be able to pass emissions when the time comes. i have a 1995 gt, and i was talking to a mechanic that said the check engine light on the 95's dont turn on without cats, but iwant to make sure i'll pass the tests. if this is the only mod along with a cold-air intake, will i be able to pass the emissions and if not, what can i do to my engine to make sure it passes? or is all hope lost?
ctlazersplaya07 is offline
Old 06-30-2008, 10:34 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: passing emissions
it depends on the test they do..if it's a visual then no and here in md pre obd II cars are run on th IM 240 TREADMILL TEST...IF YOU have such you will fail..and some states do a tail pipe test in which you most likely will fail to...you'll need cats to pass
mjr46 is offline
Old 06-30-2008, 10:39 PM
ctlazersplaya07
isnt the obd ii test just a plug in....so if they do that....because my car doesnt have any downstream o2 sensors....wont it be okay....or can i use MIL eliminators to give it the dummy reading it needs?
Old 06-30-2008, 10:55 PM
mjr46
mjr46's Avatar
your car doesn't have OBD II so they will not be plugging into it......not sure about the state regs where you live but it'll either be a tail pipe test or a treadmill test where the output of emisssions will be measure out the tailpipes and you need cat's to reduce the levels to where it'll pass fed/state specs
mjr46 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
TCStangerv6
10-11-2015 05:57 PM
Teddi
09-29-2015 12:24 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: passing emissions
