What's the largest size injector that you can run with a stock computer?
RE: What's the largest size injector that you can run with a stock computer?
match the injector with the MAF and with your application.
A chip with a custom tune will always be helpfull to the ecm, despite its adaptability.
ORIGINAL: njserrano
How large canI go for injector size with a stock 1988 computer? I want to run a single turbo 408w
Thank you
Thank you
exactly ... is it sd or been converted to maf.?
and your gonna need some big injectors for a 408 and a turbo, my buddy has 42 lbs inj's on his n/a 408 and makes about 440rwhp and he is closing in on their limit.
ORIGINAL: jtmustang
whats his setup
Sorry guys...I wanted to know how large you can go without needing "low impedance" injectors. It's a CA car, so it's Mass Air. Do they make 50-60lb injectors that would work.
I want to run a 408, 210cc heads, roller cam, 9.0:1 comp., and single turbo (boost and mm are TBD)
I plan on using a Gen 4 PMS for tuning
im pretty sure there are injectors out there that near 100#'s if not more that aren't low impedance that require an injector driver. now who sells em are a different story[>:]
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
11-09-2016 11:44 AM
NorthAmericanTuning
03-18-2016 11:21 AM
Soldier GT
08-12-2015 03:46 PM
mustangsrforever!!!
08-06-2015 12:04 PM
