Valve cover gaskets
Old 07-05-2008, 07:50 AM
mustang86cars
mustang86cars's Avatar
Default Valve cover gaskets
I asked this once before and was a little confused on the responses I got. In order to replace the valve cove gaskets on my 86GT, does any of the intake components need to be removed?
After looking at it, I cant see how I would gain access to the valve cover bolts near the intake.
mustang86cars is offline
Old 07-05-2008, 07:55 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Valve cover gaskets
the upper plenuim must be removed
mjr46 is offline
Old 07-06-2008, 06:48 AM
mustang86cars
Thanks
Is it difficult to remove the upper plenuim and do I need to worry about torque specs on the reinstall?
Old 07-06-2008, 08:56 AM
mjr46
mjr46's Avatar
just the upper plenuim should be all you have to torque back down
mjr46 is offline
Old 07-06-2008, 11:15 AM
tommiesgt
tommiesgt's Avatar
you shouldnt have to completely remove the upper plenum just enough to take the bolts out of the top of the driver side valve cover, all the vacuum lines can stay on as long as they arent in the way, which i dont remember them being.
tommiesgt is offline
Old 07-06-2008, 06:14 PM
vogs77
vogs77's Avatar
I just changed the covers on my 86. Did not have to remove or loosen the plenum at all, the cover rolls out from underneath just fine. The throtle body will have to be removed and just loosen the black coolant pipe from the lower intake and move it a little bit to get the other one out, just be careful not to break the black coolant pipe. Get felpro rubber gaskets instead of cork. A short extension and shallow socked will reach the bolts inthe cover under the plenum. Use a 1/4 in ratchet and extension for tight spots.
vogs77 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Dathan
10-05-2015 05:52 AM
winner99
10-01-2015 01:06 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: Valve cover gaskets
