Steering Column Wiring
Old 07-06-2008, 05:24 PM
dmurph57
dmurph57's Avatar
Default Steering Column Wiring
So I replaced my pedals in my 1990 mustang to try and get closer to my 5 speed swap, but I was having problems with the steering column going back in. I had the wires all hooked up to the wheel then ran into problems and figured I could unbolt the column again without unhooking the wires. I was wrong. So the plastic plugs got ripped from where they were plugged into the wheel and luckily didnt hurt any of them but one wire. One wire came loose from the plastic connector and I cant figure out were it goes. I tried plugging it into the connector where I thought it went, but now I have no turn signals or radio. Does anyone have pictures of the harnesses that hook up to the steering wheel or diagrams of where this one little wire might go. Thank you for the help.
dmurph57 is offline
Old 07-07-2008, 01:24 PM
FoxGT
FoxGT's Avatar
Default RE: Steering Column Wiring
You're lucky I was in the mood for taking my steering column off for you[8D]
Does this help or need a different angle? I'll leave it off for a while, I need to wire something in anyway.
What color wire came out? There are 5 wires for the turn signals on the turn signal switch, 1 power, 4 grounds. Neither of them have to do with the radio circuit though...
FoxGT is offline
Old 07-07-2008, 03:32 PM
ponyboy302
ponyboy302's Avatar
dude wheres the pictures ? atleast tell us what color the wire was something
ponyboy302 is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
Urambo Tauro
10-05-2015 09:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Steering Column Wiring
