Gear Change?
RE: Gear Change?
I will attempt to do most things butI left this one to the pro's. This link will give you some idea of what it involves.
http://www.corral.net/index.php?opti...&Itemid=26
RE: Gear Change?
It's not too hard to swap gears but you risk your gear set if you make a mistake.
Unlike a bad intake install or exhaust install. It leaks, you tighten it up, redo it, find the leak and fix it again.
A incorrectly installed gear set can ruin itself.
Luke9222
10-22-2015 11:55 PM
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
