slicks broke $hit... (LISTEN TO THE VID)
Old 07-11-2008, 09:47 PM
bikeboy587
bikeboy587's Avatar
Default RE: slicks broke $hit...
did you try to see if you have any other gears? when i genaded 3rd in the t-5 (v6) it went bang then sounded like bolts in a blender....but i still had 1,2,4,5,r.
bikeboy587 is offline
Old 07-11-2008, 09:56 PM
ckyguy68
ckyguy68's Avatar
I havent checked if any other gears work. The noise sounds like its coming from either the bellhousing or the motor. Its hard to centralize the sound. The reason i put them on is a buddy of mine had them because they wouldnt fit on his gt. I didn't even heat em up when it happened i just did a first gear roll and going into 2nd it just went boom. Heres how they look
ckyguy68 is offline
Old 07-11-2008, 10:22 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
wow!! to much tire if you don't have gears for a 28 inch 4:10's would be a place to start
mjr46 is offline
Old 07-11-2008, 10:42 PM
ckyguy68
ckyguy68's Avatar
I have 3.73s... Like i said my buddy gave em to me its not like i took it straight to milan and launched it at 5k.
ORIGINAL: mjr46
ckyguy68 is offline
Old 07-11-2008, 11:23 PM
jus4fun
jus4fun's Avatar
I run 4:30's and a 28 inch tall M/T slick Leave at 3K with the brake and bottle on.Thing is ,those tires will always find a weak spot. I run a Built REDNECK c4, did you upgrade any internals when you went thru the trans? try putting the rear on jackstands and turning the rear wheels by hand you should be able to feel something. And Zach that black 87 from the eldersburg lot goes 11.60. do i have some S- to tell you about what i found inside that build
jus4fun is offline
Old 07-11-2008, 11:26 PM
Explosive
Moderator
Explosive's Avatar
That sucks man.
Explosive is offline
Old 07-12-2008, 02:26 AM
mxrider426
mxrider426's Avatar
Those use to be my slicks. I also have a 3.73. 1st and 2nd gear with those tires are crazy. They are too tall for a 3.73 tho. And if you just built that trans then you may have not done somethin right or had cheap parts. I have launched on those slicks pretty hard with my car with an aod driveshaft (the one with the tiny u-joints) and never had any problems. Did you try and speed shift?
mxrider426 is offline
Old 07-12-2008, 02:40 AM
ckyguy68
ckyguy68's Avatar
Are these the ones tom got from you? Jason i think? But yea they didnt fit on his car and i thought what the hell. The trans stood up to plenty of powershifts on the spray since i rebuilt it. No noise or anything i took my time when i rebuilt it. I think it was just a little too much rubber for the ol t5.
ORIGINAL: mxrider426
ckyguy68 is offline
Old 07-12-2008, 02:45 AM
mxrider426
mxrider426's Avatar
I had them before jayson. I have a t5 in my car too and everything did fine with those slicks.Power shifting is what more than likely caused it tho cuz ofall the traction. But yea looks like you will have to pull it again
primetime5.0
primetime5.0's Avatar
time to upgrade
primetime5.0 is offline
Quick Reply: slicks broke $hit... (LISTEN TO THE VID)
