My GT went from running great to crap instantly
Old 07-19-2008, 03:22 PM
88TTop
88TTop's Avatar
Default My GT went from running great to crap instantly
Last Saturday I drove it for over 300 miles. It ran great for the whole trip although when I arrived and let off the gas in the parking lot it wanted to stall. Still ran very well on the trip home but a friend who was driving behind me said when I got on it there was a strong smell of fuel. The car sat for the next five days. I took it to work Thursday, it ran well. When I started it to go home it ran horribly.Motor shook like it had a radical cam and alot of black smoke from the exhaust. I drove it home and while there was decent power, the car hesitated alot. Help!!!!!!!!!!!!!!!!!!!!!!!!
88TTop is offline
Old 07-19-2008, 03:31 PM
silver91gt
silver91gt's Avatar
Default RE: My GT went from running great to crap instantly
a sparkplug wire or 2 may have came off, but if theres a heavy fuel smell, pull all the plugs and replace them. thats a sign that only some of the plugs are firing.
silver91gt is offline
1989LX
1989LX's Avatar
i could be wrong but sounds like a timing issue, maybe bad cam bearings, distributor gear, or timing chain. just my thoughts. hope this helps
1989LX is offline
Old 07-19-2008, 03:35 PM
88TTop
88TTop's Avatar
All the tune-up parts are new. Plug wires are secure. Checked to see if timing had jumped...it had not. As far as something internal I dont know. It has good power at WOT but it still hesitates and spews black smoke.
88TTop is offline
Old 07-19-2008, 03:37 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: 1989LX
I doubt it! and bad cam bearings??/ wtf??.............anyway sounds like you have a misfire and not hitting on all cylinders....run a koer/cylinder balance test and see where the misfire is
mjr46 is offline
Old 07-19-2008, 03:38 PM
mjr46
mjr46's Avatar
ORIGINAL: 88TTop
new as in what?? you just put them on to try and correct issue??? also check fuel pressure...if regulator is bad it may be pulling in excess fuel through a ruptured diaprahm and inturn this will mix with a/f and cause a excessive rich condition and foul plugs and then cause a misfire....pull vaccum line to regulator and make sure inside of vaccum hose is not wet with fuel
mjr46 is offline
Old 07-19-2008, 03:43 PM
1989LX
1989LX's Avatar
^^^^....as in previous experiences with ford trucks on my grandpas 1ton w/400mit was bad cam bearings causing the dizzy gear to wear down and make timeing jump, on my own was same expeience with '82 302 was same problem, only reason i chimed in was due to the "black smoke" that is what caught my eye, both of my previous experiences involed black smoke. now that was with trucks so i could be off the whole page here but it was just a suggestion...i figured i would raise an eyebrow or too......i'll keep quiet next time.
1989LX is offline
Old 07-19-2008, 03:54 PM
88TTop
88TTop's Avatar
ORIGINAL: mjr46
ORIGINAL: 88TTop
They are new parts before the problem..the fuel pressure is good...and the regulator is dry...thanks
88TTop is offline
Old 07-19-2008, 04:02 PM
mjr46
mjr46's Avatar
so if you are 100 percent positive all secondary and primary ignition components are good and fuel injection system is operating properly and you have performed a koer test and have no codes.... then do a compression test and see if all cyl are worthy of producing compression for cumbustion
mjr46 is offline
Old 07-19-2008, 08:08 PM
88TTop
88TTop's Avatar
ORIGINAL: 1989LX
Any suggestions are welcome as I havent solved the problem. Thats why we come on here.
88TTop is offline
Quick Reply: My GT went from running great to crap instantly
