Car wont start even with new battery
RE: Car wont start even with new battery
With it not diming the lights i wouldent think it would be the post tho it makes the most sence to start there i would turn the key on put the ca in park or neutrul and try jumping the selonoind just to see what happend most likely a ground wire but if the battery had bin going down and making the starter drag its posible it could be burnt up. Good Luck
i got a test light, new positive battery terminal, still the same, i got a starter solenoid but when i put the bolt on to tigthten the wires, the copper broke, so im going to exchange it. With the test light, i put it to some of the wires from the old soleniod, and it lit up, so does that mean the soleniod is still good? Btw where can i test the starter with the light?
key held in crank position put test light on side of selonoid that has cable that goes to starter..it should light the test light up..if it does and the starter is bolted tight to bellhousing then I would assume you have a bad starter
i have this problem also
twist the terminals on the battery,
i know at night if i have somone sart the car and it does it i can see the negative terminal shoot a spark out
Milan Dragway
08-12-2015 03:43 PM
'stangdude
08-12-2015 01:27 PM
