clutch problem
Old 07-30-2008, 08:27 PM
Tberg725
Tberg725's Avatar
Default clutch problem
alright fellas i was just wondering could a bad clutch cable cause my clutch to be hard as a rock to push in???? my clutch only has about 10k miles on it and ive tryed adjusting my firewall adjuster no deals......
Tberg725 is offline
Old 07-30-2008, 08:41 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: clutch problem
yup. if there is any binding in the cabe itself, itll make it hard as hell to push
AdderMk2 is offline
Old 07-30-2008, 08:42 PM
89stanger1989
89stanger1989's Avatar
yes it will. most of the mustang clutches arehard anyway unless you get yourself a centerforce.
89stanger1989 is offline
Old 07-30-2008, 08:53 PM
98redstang
98redstang's Avatar
See everyone says most are hard to push but my buddy just got an 02 and he let me give it a try and the clutch was like butter. My clutch on the other hand is ridiculously hard. I calves of steel nowor should i say a calf of steal lol. I think i might just need a new one though cause the tob is gettingnoisy. So im gonna do a new clutch cable quadrant all that crap and hopefully itll be better. But if your saying you only have 10,000 miles soi would just check the cable like the two above me are saying. I've driven 10,000 since i got my car 8 months ago so i know the clutch has a least that many miles and most likely many more so its a different story for me.
98redstang is offline
Old 07-30-2008, 09:52 PM
Tberg725
Tberg725's Avatar
Thanks for the responces guys, I pulled the cable and the casing was torn where it goes threw the bellhousing.
Tberg725 is offline
Old 07-30-2008, 11:20 PM
hayden
hayden's Avatar
+1
check to make sure it is routed correctly
hayden is offline
Old 07-31-2008, 12:48 AM
Tberg725
Tberg725's Avatar
Im going to buy a new cable tomorrow....is there any real difference between a stock oem from autozone and say a steeda?
Tberg725 is offline
Old 07-31-2008, 08:31 AM
Jfsram
Jfsram's Avatar
I bought a Steeda about a year ago. My pressure plate is 2300lbs.
Compared to my old frayed one. My clutch pedal seemed light.
About one month ago I noticed my pedal not quite as smooth as it was a year ago. Took the cable out for a lube job. One strand was broken. Lubed it anyway and reinstalled. A bit smoother but it left me wondering about the quality with Steeda cables.
I'll bet 90% of driver's would not notice the difference of one strand binding, even knowing, I can hardly tell.
When the budget allows, I will consider something better. Any ideas?
Jfsram is offline
Old 07-31-2008, 12:55 PM
945LSTANG
945LSTANG's Avatar
the OEM cable is thicker. i broke my steeda cable in 9 months.
theres an OEM cable on there now.
945LSTANG is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
MasterLanMan
09-13-2015 08:21 PM
Brandonfilipponi@yahoo.com
09-12-2015 11:39 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: clutch problem
