bored .060 over
Old 08-02-2008, 06:31 PM
redtxlx
redtxlx's Avatar
Default bored .060 over
hey this may be a dumb question, ive been thinking about it for a while kinda half wondering. if my 302 is bored .060 over whats the displacement?
redtxlx is offline
Old 08-02-2008, 08:05 PM
OneFine89Mustang
OneFine89Mustang's Avatar
Default RE: bored .060 over
if your stock block is bord 60 over your block will blow up..that would be some thin cylinder walls
OneFine89Mustang is offline
Old 08-02-2008, 08:07 PM
jssblues
jssblues's Avatar
you dont go .060 over on a 302
jssblues is offline
Old 08-02-2008, 08:27 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
.060 is not gonna blow it up ..I have seen a fair amount of .060 302's running normally.. a friend had one in his mild 65 fastback.......although not the most recommended and thinner cylinder walls reduces cooling system capability.......the standard is .030 and .040 would be fine to but if you ever have to punch a 302 to .060 I'd look for a new block..if however you are looking for power increases.. the bore of such won't give you a noticable power increase
mjr46 is offline
Old 08-02-2008, 08:34 PM
woodsy
woodsy's Avatar
310
woodsy is offline
Old 08-02-2008, 10:28 PM
tinman
tinman's Avatar
+1
310 on the money.
If you have something like an early ('6872) 302 block, they'll sonic test ok for +.060 overbore.
At least mine did...........
tinman is offline
Old 08-02-2008, 10:58 PM
woodsy
woodsy's Avatar
I got an 1980 block here that is .060 over and still .150 thick in the cylinders, last just fine at those numbers. Don't automatically dismiss .060 over on a 302
woodsy is offline
Old 08-04-2008, 06:34 PM
redtxlx
redtxlx's Avatar
pretty sure my car is bored .060 over, i bought it this way, and it hasnt blown up or anything, i was asking for displacement. not whether or not to do it. thanks.
redtxlx is offline
Old 08-04-2008, 07:27 PM
mjr46
mjr46's Avatar
run it hard ftw!!!
mjr46 is offline
Old 08-04-2008, 07:30 PM
mattdel
mattdel's Avatar
it wont blow up, it'll crack right down the middle
mattdel is offline
McLeary
03-14-2016 07:50 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
JayGee
09-15-2015 12:41 PM
FivePointToTheOh
09-14-2015 03:35 PM
Faolan65
08-27-2015 06:40 AM
Quick Reply: bored .060 over
