rough idle and smokes
Old 08-07-2008, 05:05 PM
etsxp
etsxp's Avatar
Default rough idle and smokes
so guys i bought a cap and rotor kit from summit wich also came with plug wires andac delcospark plugs so after install i start it up and it had a rough idle and islacking power. so then i realise how dumb i am and didnt gap the plugs so i take them out gap them to .045 and put them in and walah it runs like a dream! but now 91 miles down the road it has a rough idle and is lacking power and smokes like a diesel truck! idk what to do i already took out all the plugs on the driver sid there fine so i am just dumbfounded ! what is the weriedest to me is that it runs fine for miles and miles and then outa nowhere it starts to fu*k up on me [:@] just need some advice thanks guys
etsxp is offline
Old 08-07-2008, 07:41 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: rough idle and smokes
have you tried to run a koer test and check for codes?? also check fuel pressure.. I had one that'd do that once ...ran just fine then out of nowhere..it'd run bad and blow black smoke..never wouldd of found it ..had I not had the fuel pressure gauge hooke dup when prob occured....pressure out of nowhere would spike to 90 psi then drop back to normal = bad regulator...just an idea.. not saying it's your prob
mjr46 is offline
Old 08-07-2008, 08:57 PM
white93pony
white93pony's Avatar
agreed^^^ also might try to check the plugs i havent already checked!
white93pony is offline
Old 08-08-2008, 03:59 PM
etsxp
etsxp's Avatar
Thanks to all of u i mean it has been siting for two years andd then i turned it into a daily driver what do i expect[>:]but ya i definatly will try the fuel pressure and will check the codes again just when i did run a code check i reset the battery like 5 minutes befor on accident so ya this is kinda FUBAR! haha thanks again guys
etsxp is offline
Old 08-08-2008, 04:03 PM
Explosive
Moderator
Explosive's Avatar
Is it running rich ? Plugs fouled ?
Explosive is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: rough idle and smokes
