KEEP ON GETTING CODE 34
RE: KEEP ON GETTING CODE 34
34 - EGR Valve Position Voltage Above Closed Limit (O,R), EVP circuit has intermittently failed above the closed limit of 0.67 volts (M)
Suggestion..... try to keep the problems you're trying to fix in one thread, or site......... if you don't fix code 84, the EGR will not work, if you don't fix codes 31/34... the EGR won't work. By working one code at a time, trust me, you'll be able to fix them faster.
lincolnshibuya
12-08-2015 04:37 PM
