OVER CHARGEING!
Old 08-10-2008, 12:33 PM
droptop302
droptop302's Avatar
Default OVER CHARGEING!
Ok i have a 130AMP pa performance alternator. I also have UPR UDP'S crank pulley stock water pump pulley andthe pulley that came with the alternator. It's overcharging AMP light comes on and the amp gauge goes to the the top (18). Did not do this when i got it also it got stuck on 18volts and amp light on this morning had to turn off the car and turn it back on[:@] What do i have to do too make it not do this? You MF friend DROPTOP302
droptop302 is offline
Old 08-10-2008, 12:36 PM
mattdel
mattdel's Avatar
Default RE: OVER CHARGEING!
take the alt to autozone. have them test it.
more than likely all you need is a new voltage regulator. no idea where you'd get one for that though.
mattdel is offline
Old 08-10-2008, 01:47 PM
Venomantidote95
Venomantidote95's Avatar
To make sure it isnt just a faulty gauge get a multimeter and check the output voltage on the alternator, mostof the time if you takeit to autozone or advanced or orielly`s they (dont know cause it isnt there part) and then if it is there part they can only tell you what there machine says!!
this will most likely be somethng you have to resolve, you may want to call Pa and ask them if a specific pully should be used withthere alt, on a good alt the charge range should be between about 14-18volts anyway depending on the alt output and charging system requiements, it might be a normal condition!
The manufacturer will be able to help you more than anyone else, dont speak with the sales rep talk to someone in the tech depatment!
Most of your new cars charge with 18v anyway! It probably isnt anything to worry about unless electrical components are over heating!
Venomantidote95 is offline
Old 08-10-2008, 02:07 PM
droptop302
droptop302's Avatar
ORIGINAL: Venomantidote95
Well i can tell you its not normal head lights get real bright and car breaks up when i get on it
Old 08-10-2008, 02:22 PM
Venomantidote95
That would be covered by the part of electrical components over heating! sounds like something is shorting, have you unplugged all your wiring to teh alt and reconnected them make sure nothig is pinched between the alt and bracket or the head or the cooling pipes by the alt! but teh best bet is call teh manufacturer! it is hard to find a problem thru typed words! but thats gonna be all i can offer, good luck to you!
Old 08-10-2008, 04:05 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
have a vat test peformed while alt is still on car....most likely internal reg is kaput
mjr46 is offline
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
69Volunteer
09-30-2015 10:39 AM
humpbackshooter
09-24-2015 10:07 AM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
Quick Reply: OVER CHARGEING!
