Checking TPS Voltage on a 94 5.0
Old 08-13-2008, 11:08 AM
94Blk5.0
94Blk5.0's Avatar
Default Checking TPS Voltage on a 94 5.0
Well I got a new TPS, after pulling TPS related codes. Now the question is how do I check the voltage. I hooked the postive lead to the gray wire with a white stripe via a pin. I attached the negative to a ground. Set the multimeter to 20K, yielded .76 volts. Am I good to go?
94Blk5.0 is offline
Old 08-13-2008, 12:00 PM
Joel5.0
Joel5.0's Avatar
DMM setting should be in the VDC area, use the 20 or 2 VDC position..... 20k is a position associated with resistance readings. You may want to check this tutorial.
Joel5.0 is offline
Old 08-13-2008, 12:28 PM
94Blk5.0
94Blk5.0's Avatar
Alright, it reads 0.01 when set to 20 VDC.
I dont have the option for 2 VDC.
94Blk5.0 is offline
Old 08-13-2008, 12:57 PM
Joel5.0
Joel5.0's Avatar
Keep the COM probe grounded, turn key to IGN ON and check the voltage reading from all three wires. LUK
Joel5.0 is offline
Old 08-13-2008, 01:45 PM
Joel5.0
Joel5.0's Avatar
DP... sorry!
Joel5.0 is offline
Old 08-13-2008, 02:54 PM
94Blk5.0
94Blk5.0's Avatar
Key on:
White stripe: .14
Red srtipe: -.12
Brown: 4.17
94Blk5.0 is offline
Old 08-13-2008, 03:11 PM
Joel5.0
Joel5.0's Avatar
Looks like that replacement is also fubar. Disconnect the EVP sensor and recheck voltage from the Gray/Wht wire. LUK
Joel5.0 is offline
Old 08-13-2008, 03:50 PM
94Blk5.0
94Blk5.0's Avatar
With the EGR senor unplugged, it settled at .31
94Blk5.0 is offline
Old 08-13-2008, 05:53 PM
Joel5.0
Joel5.0's Avatar
While monitoring the voltage, reconnect the EVP and check if it drops to .14 vdc. If that's the case, you may either have a problem in the wiring, or a short in one of the other sensors SIGRTN (Gray/Red) is shared with (ECT, ACT, O2 sensors and EVP). LUK
Joel5.0 is offline
Old 08-13-2008, 10:28 PM
94Blk5.0
94Blk5.0's Avatar
So do I disconnect those senors listed above one-by-one until the reading changes?
94Blk5.0 is offline
Quick Reply: Checking TPS Voltage on a 94 5.0
