EFI to Carb Problems....
Old 08-18-2008, 06:10 PM
87Stallion
87Stallion's Avatar
Default EFI to Carb Problems....
Here's my issue.
I have converted my 87 GT to carb.
I am running a Eddy RPM Air Gap Intake, Holley Street Dominator 670, Duraspark II ignition,
and a 85 GT dizzy.
I have everything wired up and the car will fire for about 1 sec and die. I am getting fuel @ 6 psi.
I have restabbed the dizzy but this one seems much harder to get right than the original dizzy.
All the above parts are brand new including coil. I am at a loss. This thing should fire right up.
I need help. I gotta get this thing running.
MJR46 helped me with the wiring for all this so I know that is right.
87Stallion is offline
Old 08-18-2008, 08:31 PM
87Stallion
87Stallion's Avatar
Nobody have any ideas?????
Old 08-18-2008, 09:12 PM
DriftingRz
DriftingRz's Avatar
haha dude, i feel your pain, when i had my last 88lx 4cyl to v8 carb i had the same exact problem when i changed over ignition to an older duraspark setup. i spent weeks trying to figure the **** out, and finally realized i just had the dizzy wired wrong, the 2 wires coming off one was going to the starter or something i cant remember so it would only get power while hte key was turned all the way over. so it would die off after like 2 seconds, it drove me freakin crazy, ill look for my old thread and see if i can remember how i wired it. i bet its the same problem
DriftingRz is offline
Old 08-18-2008, 09:22 PM
87Stallion
87Stallion's Avatar
Thanks man that would be great. This is p*ssin me off big time.
Old 08-18-2008, 09:23 PM
DriftingRz
DriftingRz's Avatar
correction: i didnt really describe it well in my thread, but i had a wire coming off the coil going to the wrong area, wire from dizzy went to - side of coil, and + wire was originally going to the starter, but that was wrong or something, i had reroute the wire to somewhere in the fusebox or something for power for an ignition on only accessory, or something, i dont know it was a while back. heres my thread
https://mustangforums.com/forum/5-0l-1979-1995-mustang/420221-is-this-wiring-right.html
Old 08-18-2008, 09:45 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
pm sent without even reading your thread I drew the same conclusion about a possible issue with where you have the 12 v source, most likely on a hot in crank only and it needs to be hot in run for both coil and box
mjr46 is offline
Old 08-18-2008, 10:33 PM
87Stallion
87Stallion's Avatar
THanks a million. One damn little wire was stopping it from running. The key on hot according to jason fletchers site is wrong. Or at least on my car it is.
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Ipaman
09-22-2015 07:01 AM
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
Quick Reply: EFI to Carb Problems....
