questions on what to do
ok so im thinking of doing a 302 turbod. im also thinkng of doing the 347 stroker and either ported heads or gt40 heads. should i do the 347 stroker? can anyone suggest a cam that will work with a turbocharged 302?
turbo'd stock mustangs can nearly push the limits of the block or with minor mods. so again what MJR and ADDER said, either aftermarket block if you're going turbo or better heads if you're hittin up the 347.
GT40's are more for a mildly built 5.0
I'd go turbo and at least get a mexican block like everyone says. Especially if you've got the money to do all this anyway.
Good turbo cams are the F cam and the tfs stage one cam. Or you could always do a custom grind.
However if it were me, and I got to start fresh, I'd probalby use 351, those stock blocks are good for lots of power AND you can get a 408...sounds like a win win to me.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
