exhaust manifold
Old 09-01-2008, 01:45 PM
  #21
mstngsule68
mstngsule68's Avatar
dont forget to retighten when warm
mstngsule68 is offline
Old 09-02-2008, 02:56 AM
  #22
88stang5.0GT
88stang5.0GT's Avatar
ive never heard that your supposed to do that before... but then again this is the first time ive built an engine from the ground up and ive had it completely apart twice and never fired it, any things else i should know about?
88stang5.0GT is offline
Old 09-02-2008, 03:01 AM
  #23
mstngsule68
new exhaust gaskets?, yep retighten a few times just to be safe..otherwise you got exhaust leaks...
Old 09-02-2008, 03:05 AM
  #24
mstngsule68
and you have all the bolts in correct? if not. dont even waste your time you gunna just blow every gasket you put in like that. and plan on nothing but neg side effects.
Old 09-02-2008, 03:25 AM
  #25
88stang5.0GT
no i couldnt get one bolt to go in on the passenger side... but i did finally get the one on the driver side to go in... i swear the head is ruined because the only way it will go in is at an angle
Old 09-02-2008, 04:13 AM
  #26
mstngsule68
keep trying, maybe you need to take a drill and make it a 1/8th or 1/16 wider.
Old 09-02-2008, 07:35 AM
  #27
LesteR723
LesteR723's Avatar
its hard if you keep the H pipe installed cause no exhaust is perfect. Just loosten the bolts on the h pipe where they connect to the header and it should give you enough play room to get it in straight ;-)
LesteR723 is offline
Old 09-02-2008, 09:49 AM
  #28
Shelty
Shelty's Avatar
Originally Posted by projectresto83
+1. We need another noob to come back on and start claiming things so we can bash them again. It has been awhile.
like the ravenforbidden guy who claims he has a skyline?
or that guy who ran water through the motor of his cobra...
or that other guy who swears by ebay turbos?
Shelty is offline
Old 09-02-2008, 12:02 PM
  #29
88stang5.0GT
i have room i can see the hole where the bolt is supposed to go and nothing is pushing it sideways or anything idk what happened to it last time i put them on they all went straight in
Old 09-02-2008, 02:22 PM
  #30
mstngsule68
keep trying...you have every bolt loose while your tryin to put them in right?
Quick Reply: exhaust manifold
