Pulled Code 41,replace 02 sensor right?
Old 09-02-2008, 09:45 PM
04fivefour
04fivefour's Avatar
Default Pulled Code 41,replace 02 sensor right?
Pulled code 41 KOER self test, description says no 02 sensor switching, code was in memory, anyone with experience with this code have any input, seems very straightforward, replace 02 sensor or look for open/short in wiring?
04fivefour is offline
Old 09-03-2008, 05:28 AM
Joel5.0
Joel5.0's Avatar
If the O2's are old and have some mileage on them, replacing both is a good alternative. Also make sure the passenger side header doesn't have any exhaust leaks causing the lean readings at that sensor. You could also switch O2 sensors from sides, rerun the KOER, and if code 91 shows afterward, it will confirm that sensor is at fault. LUK
Joel5.0 is offline
Old 09-03-2008, 07:34 AM
AdderMk2
Banned
AdderMk2's Avatar
did you run th test while the engine was at full operating temperature???
AdderMk2 is offline
Old 09-03-2008, 08:06 PM
04fivefour
04fivefour's Avatar
yes, right after a long freeway drive, i'll try swappin side to side
djbigskrilla
09-20-2022 01:04 AM
bryan616fl
01-25-2019 09:07 PM
mirandaandjimmy
11-16-2015 08:51 AM
nwday
3.7L V6 Technical Discussions
09-01-2015 11:21 AM
microgt
08-20-2015 07:12 AM
Quick Reply: Pulled Code 41,replace 02 sensor right?
