Everything keeps going wrong
Old 09-09-2008, 08:02 AM
n0th1n2kn0vv
n0th1n2kn0vv's Avatar
Default Everything keeps going wrong
I have a 1995 Mustang GT with the stock 5.0 HO. I know this sounds weird but I installed lambo door hinges on it awhie back. The drivers window stopped working 2 months ago and somehow I managed to fix it. Last week, my window stopped working again (its down and wont go up). The window motor makes a click sound when I hit the up button.
Also, the right front mach460 speaker and the right rear speaker both do not work. If you turn it up really loud, the sound comes out but its static and very soft.
The drivers power seat has a mind of its own too.. It worked when I got the car (, blew a fuse, and may have blown another fuse (not working now).
Does anybody know why this is happening? short somewhere? Its pissing me off.
n0th1n2kn0vv is offline
Old 09-09-2008, 08:51 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
could be a short....could be that the car is 14 years old and stuff just goes bad. check the fuses, pop the door panel off and check the motor to see if its getting power, if its not make sure the switch is gettin power....that should narrow it down. so check the fuses and if they are bad then stat wire hunting.
as for the spearks make sure the wiring didnt pop loose, if it still has good connection then maybe the speaker is bad.
FivePointOhh is offline
Old 09-09-2008, 10:17 AM
aode08
aode08's Avatar
speakers- bad voice coils replace speakers
window only one direction(common/no operation), grounded driver window switch/repalce
power seat motor / common -replace
aode08 is offline
Dokilar
15
10-16-2015 08:13 PM
Matt's 95 Stang
10-05-2015 07:16 AM
ChampInSD
10-02-2015 04:55 AM
marc954
09-29-2015 11:18 AM
Quick Reply: Everything keeps going wrong
