maximum cam lift with stock springs?
Old 09-13-2008, 02:01 PM
F150 StrokerCobra
F150 StrokerCobra's Avatar
ok... on the PR's
here is the valve locks
http://store.summitracing.com/partde...art=CCA-611-16
retainers
http://store.summitracing.com/partde...art=CCA-740-16
are they a yes? will they work?
F150 StrokerCobra is offline
Old 09-13-2008, 02:43 PM
Joel5.0
Joel5.0's Avatar
Regarding the retainers, you need to have a shop make sure those will provide the required closed valve height for the springs specifications, if they don't, they might have to be exchanged by retainers with the correct offset.
Joel5.0 is offline
Old 09-17-2008, 09:36 AM
5spd GT
5spd GT's Avatar
Piston to valve clearance is not dictated by peak lift (rockers included) or peak lobe lift.
5spd GT is offline
Old 09-17-2008, 10:08 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
Originally Posted by mjr46
I gaurantee he is not reaching trhe full potential of that set up with stock springs, gauranteed you'd see it on a dyno where it falls flat in the upper rpms
thats exactly what happened on my first dyno. typhoon intake, b cam, exhaust and stock valve springs. 198rwhp and after 4k rpms it just seemed to level off.
after the spring install, few more minor mods(electric fan, 73mm MAF) i was in the 230's with a nice upward slope, no flat spots.
FivePointOhh is offline
Old 09-17-2008, 03:40 PM
FoxGT
FoxGT's Avatar
I'm running an x303 on my stock pistons/springs/retainers/rockers @ 542 lift. I've been running it for probably 30k miles. I don't turn over 4600 rpm with it because I don't want this engine to see higher rpms until I can get around to replacing them.
I definitely wouldn't recommend it, i'd say get the springs to go with. It can be done though.
FoxGT is offline
Old 09-17-2008, 06:46 PM
maroon89lsc
maroon89lsc's Avatar
Originally Posted by 1988TTOP
if u r puttin in a stock motor u will need to notch the pistons max lift is 540
acually it depends on the heads you run if you have gt40 or gt40p heads you can run a cam with up to .550 a head with 2.02 valves you can run up to .500 lift just for your info so you dont tell people wrong.
maroon89lsc is offline
Old 09-17-2008, 07:14 PM
Joel5.0
Joel5.0's Avatar
Negative..... GT40/GT40p heads (Explorer types) use a valve spring similar to the E7 heads, the only Gt40 heads that had better springs were the Cobra engine ones. Anything above .470" lift is a gamble however, it's not just the lift limitation, the stock springs do not have the spring rate to better control the valve train. Again, stock springs = stock cam. BTW..... total valve lift specs have nothing to do with PtV clearance issues..... with any intake valve diameter.
Joel5.0 is offline
musnicki
09-23-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
Insidian
Carolina Regional Chapter
09-08-2015 05:33 AM
RWHEELS
09-05-2015 03:42 PM
Luke9222
09-04-2015 06:46 AM
Quick Reply: maximum cam lift with stock springs?
