Holley carburetor issue
Old 09-25-2008, 11:15 PM
import slayer
import slayer's Avatar
Default Holley carburetor issue
I helped my friend install a new power valve in his 650 holley. We scraped all the old gaskets off the surfaces, installed the new valve and put it back together. When we started it up, fuel was spraying from the vent tube. It wasn't pouring out but you could see a light mist of fuel coming out.
What would cause this? I told him it was possible that a piece of the old cork gasket got into one of the tiny carb. holes when we were scraping the gasket off, since we did it with the carb on the car.
We tried to be careful when we did it and used a shop vac to suck up the debris every now and then.
What should we do? Take the bowl off again and hit the holes with an air hose to dislodge and debris that might have got in there?
import slayer is offline
Old 09-26-2008, 12:06 AM
Jfsram
Jfsram's Avatar
There is probably dirt stuck in the needle and seat.
Holley carbs have zero tolerance for dirt.
Jfsram is offline
Old 09-26-2008, 01:17 AM
mstngsule68
mstngsule68's Avatar
adjust the float level. and make sure you have only 5/6psi in it.
mstngsule68 is offline
Old 09-26-2008, 07:03 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
make sure you got the bowl back on right so the float isn't hanging up
mjr46 is offline
Old 09-26-2008, 02:29 PM
import slayer
We never messed with the float or it's settings....
Old 09-29-2008, 04:14 PM
mstngsule68
if u took the bowls off, maybe u bent the float. or did something to them, take it apart and check it..........
Old 09-29-2008, 07:35 PM
mjr46
mjr46's Avatar
when you put the bowls back on if your not careful you can mess up the float setting
mjr46 is offline
cr620
10-03-2022 10:18 PM
Thunderball
15
11-22-2015 11:49 PM
chrisdbassplayer
10-13-2015 06:53 PM
Bokeo
10-10-2015 08:28 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Quick Reply: Holley carburetor issue
